Both my 436 and 536 hang, freeze, stick, on the boot screen when powered up. On my 436, I must remove the batteries to get it to boot again past the boot screen. On the 536, I must physically disconnect it from power, as even turning the volume switch to off does not power down the scanner.
This is seriously annoying me, especially now that I am starting to play with them. Was planning on installing a fleet of these in a mobile vehicle console, but that is not a possibility if i cannot turn them on or off obviously. Is this a known issue, or part of that uniden repair campaign? Is there a fix for it? Will be moving to Whistler if this is not something that can be fixed, because it is not a problem that can be lived with in a busniess enviornment.
Should mention this was doing this on 1.10 f/w, and still does it on the new DMR f/w.
Paul
Paul
