If anyone who has successfully done this on the SG CO system could help me troubleshoot, I would greatly appreciate it. I've followed the steps above to a T, but still not receiving. I suspect it is something in the Trunking Configuration that's not right, but I'm not sure. PMs are fine if you prefer. Thank you.
Do you have the right band? For Sedgwick County's system, it's non-standard.
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,809.06250,0.01250,-45.00000,"Confirmed",0.01250,1
Also, "XTS/XTL radios are configured to validate the NAC against the System ID. If a match is not found, the radio does not attempt to register/affiliate to the trunking site. Also, scanning a trunking system from a conventional channel will not be possible. This validation does not take place when Intra-WACN Roaming is selected and the coverage type is set to SmartZone. By changing those settings, an XTS / XTL radio can be used on a Harris or other system that uses a System ID / NAC configuration that does not otherwise validate. However, an Advanced WACN Key (AWK) is required to change those settings."
Should put you on the right track.
Jacob
