mavrickma
So I have my 536HP installed in my new 2016 F150 that does the auto start/stop at stoplights and such. The radio is wired into a relay that is powered off a dedicated power line and triggered by the vehicle's accessory wire. Radio is grounded to a chassis ground (with several other items). Everything works great, except when I lift my foot off the brake and the engine restarts (not by key, but by auto function), the scanner reboots.
I've tried adding 26700 microfarads of capacitance to the circuit, a diode to prevent backfeed into the vehicle circuit (and loss of capacitance), an inverter (DC Noise filter) to help prevent spikes and a 13V/5W zener diode to also help prevent spikes. Nothing I do seems to stop the issue. It seems to not reboot until after the engine has started, so I'm starting to wonder exactly what the issue is. I have a Uniden CB wired into the same circuit as the scanner and it does not fluctuate at all. Neither do any other electronics that I have added.
Does anybody have any ideas how to fix this? I'm at a total loss.
Thanks in advance,
Brandt
Thanks in advance,
Brandt
