Frequencies
cajunjerry
Springhill,La.
Hello all
So I know that you mostly have to put in a control freq and a alternate. But what happens if you put in all the frequencies. Jerry from Louisiana
nd5y
Wichita Falls, TX
Hello all
Normally nothing happens.
If the system changes the control channel to one that isn't marked red (primary) or blue (alternate) in the database that you don't have programmed then you will not be able to receive anything any more.
It doesn't hurt to program all frequencies in case that happens.
nd5y
Wichita Falls, TX
I should have said that for a Motorola or P25 system nothing happens.
Other types of systems such as LTR and EDACS require all system frequencies to be programmed in the correct LCN order you won't receive anything or only receve bits and pieces.
