XTS 1500 MDC help
wfrancis16
Hudson, MA
My department uses MDC for identification of each radio. I am having an issue with each radio displaying the ID when it is received. When the transmitting radio is on direct, the receiving will display the MDC ID. When the transmitting radio is in on a dispatch channel, the MDC ID is not displayed. I would like to have the ID displayed in both modes. Is there a setting that I am missing somewhere?
MTS2000des
5B2_BEE00 Czar
Is the MDC1200 actually going over the repeater and not being muted out? If you can receive the ID on talkaround but not through the repeater then it sounds like the receiving system is programmed for data operated squelch so that only the consoles receive and log/display the ID.
wfrancis16
Hudson, MA
The MDC ID is going through the repeater. We have some HT1250s and they receive and display the ID fine. Only the 1500s will not display the ID.
KC2JS
NJ
What is the flashcode of the 1500s? It has to start with 1 or 5 (IIRC) to display IDs.
Did you program it properly assigning the mdc personality to the conventional perosnality and selected mdc as well as checking the ptt Id box for transmitting? In the radio wide ensure the display id feature is checked if your 1500s are model 1.5s. Ensure your personalities are matching if the talk around is showing ids but the repeater channel isnt.
