You're not helping.P25 isn't necessarily encrypted. Ontario Provincial Police use P25, and can I listen to the dispatch channels. Maybe this "new" P25 system you are referring to is encrypted, but according to the RR database, Ottawa Police use Pro-Voice not P25. When I'm listening to the OPP, the scanner indicates the channel is P25, and when listening to the Ottawa Police, the scanner is indicating Pro-Voice. Cheers!
Encryption has been seen on the new P25 system, so enjoy your listening while you can.
All of this information is in the RR database.
We all know what systems the OPP use and they're not P25 systems. They're older Type II SmartZone systems with a few encrypted users. This thread is about the Ottawa police on their new, real P25 system. It's not about the OPP and it's not about Ottawa PD on their old system. Virtually all of these new P25 PS systems are set up with full time encryption for the PD members. Many even encrypt FD. So what's your point again?OPP in my area are on Bell Fleetnet Zone 2 which uses both Motorola Type II and Apco Project 25 according to the RR database, and P25 is what is indicated on my scanner when listening to the OPP.
Somebody had better get their info straight. OPP are P25 digital in all areas.
ProScan logs OPP transmissions as P25.
OPP in my area are on Bell Fleetnet Zone 2 which uses both Motorola Type II and Apco Project 25...
Slicerwizard IS correct. Bell Fleetnet in Ontario is comprised of 3 Motorola Type 2 Smartzone trunk systems. The control channel is 3600bps
Bell Fleetnet is 4 Smartzone systems running 3600baud control channels.
In summary, as the final current agencies currently on the City's EDACS system move over the the P25 system, you will not be able to monitor the communications using conventional methods.
Please correct me if I am wrong...
I've been able to listen with my 396T scanner...
Ottawa Public Safety (Project 25) Trunking System, Ottawa, Ontario - Scanner Frequencies
Some talkgroups on this system are using Project 25 Phase II TDMA modulation which can ONLY be monitored using a P25 Phase II compatible scanner.
There's already a thread started here: http://forums.radioreference.com/ontario/304191-ottawa-p25.html
I think the DB comment about Phase II may be premature. The system is capable, but I have yet to see/hear of any actual use of Phase II; unless someone knows specifically to the contrary.
