I recently got a UHF VX-2200 radio. I have programmed it up to the 16 channels I plan to use it on. I have added the encode and decode tones, but I am still hearing the repeater ID even though the PL tone should be blocking that out on these channels. Maybe I am missing something in the programming.
Also, on 1 channel in particular there sounds like there is an open mic at all time, however I can conform there is not since I do not hear this on any of my scanners or other radios on the same channel. When a transmission does come across on that channel, it sounds very garbled to the point where you can't understand it. I have tried playing with the squelch level with no luck. It only does this on 1 frequency and no others. Any ideas?
