My organization works overseas in dangerous areas. We currently use MTS2000 450-520 MHz UHF radios with DES-XL encryption. Most of our work is done in urban areas where the buildings are mostly 2-3 stories tall.
The MTS2000s do not have enough power to transmit even close to a mile in these urban environments, and we need a minimum of 3 miles range. The more, the better.
Setting up a repeater and antenna on a tower is not really an option because we move so much. We would like to mount a repeater and mobile radio in our pickup truck that will give us at least 3 miles range in these towns/cities with low buildings. Our personnel are always going to be within 3 miles of the truck when we use the radios anyway.
We believe that the best mobile radio for us is the high-power XTL5000 380-470 MHz UHF 100 watt model with a DES-XL encryption module. This meets our mobile radio budget of around $1,000 used. Our budget for a used (or new) repeater is also around $1,000. There are some additional funds available for the antenna, duplexer, etc.
Here are the problems/issues that we really need help with:
- We are considering the Futurecom DVRS repeater, but are not convinced that 10 watts output power is sufficient, nor can we find affordable cables to connect it to a XTL5000 radio anyway
- We are considering using a MTR2000 435-470 MHz UHF 100 watt repeater, powered using a DC to AC inverter in the truck. Paired with the 100 watt XTL5000, won't this give us plenty of power and range?
- We are open to other repeaters also like Bridgecom, Kenwood, Vertex, Pyramid, etc. if one would be better suited for our application.
We would greatly appreciate any advice on how to design a system that meets our requirements and is close to our budget. This is a time-sensitive request for help as we need to put this system together in the next 10 days. Thank you.
