BCDx36HP DMR Preview 4 Available
UPMan
In Memoriam
Arlington, TX
Download (and yes, there is a new password to get to the new stuff) is at this link right here.
-- New Supported and Modified Items --
1. Modified LCN Finder
2. Improved tracking in CAP Plus
3. Supported RAS in CAP Plus
4. Improved connection to the control channel in CON Plus
5. Modified display order for source ce ID and destination ID of DMR Private Call
6. Modified display switching of color code
7. Modified swapping to Quick Search on searching in Conventional Discovery
8. Supported recording Network ID, Site ID and TGID in Conventional mode
9. Changed format of DMR Activity Log
D
darunimal
Guest
Thanks for all the Beta firmwares, keep up all the hard work.
woodpecker
I left the LCN finder running, don't know how long it exactly took but when I came back 40 mins later it had found 3/3 on a Cap+ system so looks good!
werinshades
Chicago , IL
I figured something was up as the previous Beta versions were missing from the Wiki. All done...I'm down to about 30 seconds loading this in. 1.11.10 installed...report to follow.
UPMan
In Memoriam
Arlington, TX
Hmmm. I guess I need to make the payload password harder to slow you down a bit. How about next time, "the password is every 3rd letter of every other word in item 4."
bravo14
Polk County FL
Gives me a error when I put password in. I know where the password starts I copy and pasted nothing happens
So Far Away....
dont know what you all did,
but...
Im getting a snappier response on
analog and digital - 138.xx p25,
and 155's public safety..
also getting better RX on 460's
p25..
no change to the set up , just the FW
upgrade...
UPMan
In Memoriam
Arlington, TX
Bravo: VLC is a media player. Can't imagine why it is involved at all.
WinRAR isn't necessary (for versions of Windows past 7...maybe before that). Just open with Windows Explorer.
There are no differences in encryption between this and any of the other pre-releases (other than the password itself).
bravo14
Polk County FL
I had no problem with the other 3 previews using winrar on win7. I'll try windows explorer.
Edit I got it going.
UPMan
In Memoriam
Arlington, TX
A common issue in copying/pasting is accidentally copying the space before or after and missing a letter when copying. Either would result in a copy/paste fail.
werinshades
Chicago , IL
Copy and Paste are nice inventions ! So far so good on the CAP+ system. More testing to come...and more coffee!
