help with DMR
55engine
Hartford County area
Is there anybody that is receiving DMR that could help me out I have the key I put it in I'm having troubles picking up DMR if so please PM me thank you
garys
If you're referring to the feature key to activate DMR, you're question is best asked in the Uniden forum.
MFCJR
I was just about to tell him the same thing. There is a lot of info on that in the Uniden forums.
cg
Connecticut
Did you program it in or are you only relying on the Close Call to hear it? You can program it in by hand and be sure if you are hearing it or not.
chris
cg
Connecticut
Rentschler Field is Tier III trunked, they have an event there on the 25th if you want to test itI
You can try the OneVoice site in Farmington. System is Con+
chris
cg
Connecticut
The Farmington OneVoice site is incorrectly listed as Hartford, it is Site 26 and is at Rattlesnake Mtn.
Use MotoTRBO systems for the OneVoice and Rentschler TierIII and then use DMR one freq for UCONN.
chris
