dpincins
In an effort to boost my receiving abilities I purchased a dual band preamplifier from Scanner master. I am having trouble finding a source to power the pre-amp. I would prefer running a coax cable from the center input (so239) to an outlet in my house, but I am unable to find something that matches the specs. I believe the correct setup will be a rg58 cable, with a so239 connector to F connector, to outlet. The antenna to preamp to scanner will be connected with a short jumper cable from the antenna to pre-amp, and then a 60' run of lmr-400 to the scanner. I already have the seperate cable and appropriate length so I would like to run the cable separately. Any help would be appreciated concerning the power supply.
Thanks!
Pre-Amp:
LNA-DUAL-VU-O Pre-Amplifier | Scanner Master
Thanks!
Pre-Amp:
