I take 1 & 2 are digital systems?
You've programmed SQKs, have you enabled them in the scanner via xx.01. And if they are digital systems, they'll need a Department Quick Key for at least ONE site, without a site enabled (by using a '.' (Always on with that Site/no DQK needed for Site(s))(or you'll need a DQK for the systems' 'Site' 'zz' (utilizing xx.yy.zz to enable/disable that Sites' DQK) there will NOT be any digital frequencies for the scanner to scan.
Program your DQK for Sites
xx.yy. Single Site s can use '.' and will Always be on, when that Favorite Lists' & System is toggled on.(you could use 0) and alway keep it on by never typing xx.yy.00 for any single-Site System
Or
xx.yy.zz Site 'zz' has the ability to turn on a Systems' Multiple different Sites on or off individual(good for bigger Systems with Multiple Site where a States or a multi-county jurisdict System, or just a county with a multi-site set-up.
