Jackson County/Mariana
WX4JCW
Stow, Ohio
Ok i am programming Marianna/Jackson County So as one Frequency trunk systems then you can read the unit ids and there is a TG
Marianna CH 2 is Encrypted
bravo14
Polk County FL
Are you able to hear the jail freq? I believe it's all color code 1 and tg is 1. I do see slot 2 here and there with the E on it. I do hear hear Jackson co in Panama City when bands are open.
bravo14
Polk County FL
I see Jackson county has powersouth energy if you program them in you won't hear much. I don't think the lcns are correct.
bravo14
Polk County FL
Here is a pdf file I have for Jackson County
  • Florida F-J Counties DMR.pdf
bravo14
Polk County FL
In DSDPlus I have the following TG for Jackson County
Marianna PD 502000 88001
Jackson SO 250001 16776415
WX4JCW
Stow, Ohio
453.7875 is CC5 but encrypted and they said go to 2 on the Marianna dispatch channel
rickou812
New to DMR, trying to program in Jackson County EMS and SO using CPS V1.16...not having much luck.
Can someone explain what is required or send a working code plug for these?
I understand the Rx Freq. for JC EMS is 155.145, but not sure what color code or talk group, etc..
Thanks for your patience with a newb..
bravo14
Polk County FL
I live about 45 mints to a hour once awhile I'll hear DMR UHF. I notice the Color Code is usually a 1. TG varies I assume. Only way to get info is DSDPlus. You'll need some dongles and a computer.
rickou812
I have ordered a SDR dongle and downloaded dsd+. Which SDR program do you recommend?
Are there any step by step guides for setup, etc.. that you recommend?
Thanks for your help!
rickou812
I got home hours ago and left my radio at home when I went on a trip going east. I went to my 536 took out analog and a dmr search and got this.
Color 1 slot 1 tg 20300. Is that you got?
I received my SDR dongle and got it setup a couple of days ago and that is the same I got.
So for Jackson County Fire/Rescue - 155.145, CC1, SL1, TG20300 is confirmed.
bravo14
Polk County FL
I heard some audio last night with 3 bars in Bay Co. I've updated it last night. This morning it was updated on RRDB.
bravo14
Polk County FL
Are you able to get the other freqs updates I know there is a few need to checked on.
wm8s
Houston, TX
What does "*" mean in the TG field on RR for many of the Jackson County channels? That the TG is unknown?
