FRS Channel 3 (462.61250mHz)
iamjimmy86
Ontario, Canada
Does anyone in the Durham Region area kow what causes the interference on FRS Channel 3 (462.61250)? I've been curious for a while, it always just comes in as a skipping sound when it breaks the squelch. Is there something or someone in the area that uses a business frequency that interferes with the adjacent channel spacing?
Also note I do have an audio recording of the aforementioned noise if anyone is also curious.
ecps92
Taxachusetts
The Adjacent Frequencies would be GMRS
see what you hear on 462.6250 and 462.6000
K2RNI
Kingman, AZ
What places are you hearing it? Have you tried moving around? Like for example is it only around the house or work? I had a similar issue with a really loud narrowband noise for a few weeks and eventually traced it down to my computer monitor by luck because I shut down as I was listening. Wiped out channel 7 while on for some reason.
iamjimmy86
Ontario, Canada
I find it anywhere I go through town. I went for a bike ride one day through town with a Midland FRS radio and everywhere I went I would hear it. The last couple years I've noticed it more and more. It's no problem if you use TPL/DPL tones as it blocks it out, but on channels with carrier only it comes in. Just curious if anyone in Southern Ontario, my area, knows anything.
wirr
Senior Member
The default frequency in John Deere GPS RTK systems used by farmers is 462.6125. Some never get changed to valid, licensed frequencies. It is kind of a pulsing sound, short transmit bursts. Maybe this is what you are hearing. I've come across these stations on a number of occasions.
iamjimmy86
Ontario, Canada
It's kind of like that, if you pm me your email I can send you the recording I took on my phone. You can let me know if it's the same sound. It's about 5-10 seconds long.
