2016 Wildfire channels
Anderegg
Enter text in this field
San Diego
So, the infernos have begun, looks to be a busy summer.
Since last year, there have been some changes. Maybe this post can serve to indicate the working channels for dispatched incidents. Perhaps just put the name of the incident, and the primary command and tac plus any additional channels they went to, including the ones that have already happened earlier in the month This will assist in determining what's getting used, what isn't, and the order of importance.
One thing I found incorrect in the RRdb is XSD Command 3 is not transmitting 103.5 PL for RX. I am listening to it on a little HAM radio, so I can't search for the RX PL, but maybe someone can correct that on the db?
Paul
K6CDO
Hanover Co. VA
Paul,
XSD Command 3 is SUPPOSED to be transmitting 103,5; the fact it isn't was noted last week during the Border Fire, and will be corrected.
f40ph
Largest County, CA
Not sure where you're getting your info, it has always been 110.9 in the CalFire statewide "group 3" radio mask. Someone should confirm before making DB changes.
Anderegg
San Diego
Northcomm has an incident working on XSD COMMAND 7 right now..........I am being told it's on "tone 4".........not sure if there is an actual XSD Command 7, or if Northcomm is mistakenly calling CDF Command 7 XSD Command 7. Anyone got info on this, and XSD Command 4 and 6 as well?
Paul
Anderegg
San Diego
They moved the incident back to 800MHz RCS.......apparently the BC said they cannot get out on "XSD Command 7". :-\
Paul
scottyhetzel
Palm Springs Area / OrCo
Here you go...
Ch. freq. repeater loc.
XSD 4 158.970. Mt Woodson(Poway) Lyons peak (East co)
XSD 6. 154.025. Morrow / Black mnt (park) / fire mountain (Oceanside) Del mar heights
XSD 7. 154.235 previously green 1. Palomar / red mountain ( fallbrook /rainbow ) Catalina (vista)
FYR955
XSD Command & Tac's
Xsd cmd 1 154.1750 103.5 158.8650 103.5
xsd cmd 2 156.2250 107.2 159.0150 107.2
xsd cmd 3 153.9950 110.9 159.1125
xsd cmd 4 158.9700 103.5 155.5500 103.5
xsd cmd 5 153.8900 150.8050
xsd cmd 6 154.0250 131.8 158.7450
xsd cmd 7 154.2350 158.9850
xsd cmd 8 155.6850 158.8050
xsd cmd 10 154.8150 103.5 158.8350 103.5
xsd cmd 21 153.8150 151.1000
xsd cmd 22 155.9550 158.9250
xsd tac 1 155.0850 155.0850 103.5
xsd tac 2 154.4300 103.5 154.4300 103.5
xsd tac 3 154.1450 103.5 154.1450 103.5
xsd tac 4 154.3100 103.5 154.3100 103.5
xsd tac 5 154.2500 154.2500
xsd tac 6 154.4150 154.4150
xsd tac 7 159.1650 159.1650
xsd tac 8 154.3550 154.3550
xsd tac 9 156.0150 156.0150
xsd tac 10 155.5650 155.5650
xsd tac 11 156.1875 156.1875
xsd tac 12 158.9475 158.9475
xsd tac 13 154.3850 154.3850 110.9
xsd tac 22 154.3250 103.5 154.3250 103.5
xsd a/g 156.1650 107.2 156.165 107.2
Anderegg
San Diego
I see SND channels get XSD designations......have not heard SD City use their SND VHF channels recently, but when they do, SND Command and SND Tac 1 are always patched to 7J and 7K.
Thanks scotty! :-D
Paul
I notice that there are 2 freq on each CMD and TAC channels my ? is what is the 2nd one. Thanks folks
K6CDO
Hanover Co. VA
The user receive frequency is listed first, followed by the user transmit transmit frequency. As noted, it they are the same, the channel (usually TACs) is simplex.
Anderegg
San Diego
Paul,
Still getting XSD Command 3 on 110.9. Hearing a lot of units last Thursday coming back to 10A reporting "can't get out on XSD Command 3", so they switch out to XSD Command 1.
Paul
