CanesFan95
Does anyone on here know how to make the old Trunker / eTrunker programs work in Windows 7 64-bit? There's a windows version of it, but it doesn't work on Windows 7. Thanks.
Whenever.Do I have to make the .bat file run at startup, or can I just run it whenever?
No, that was never the case.I thought before, you had to use autoexec.bat
If you tried to run a Windows program under true DOS, how could it possibly work? DOS knows nothing about Windows. And here you want to run a Windows program in a DOS emulator...When I try to run the Windows version ewtrnk.exe in DOSBox, it gives some message about Windows NT and it doesn't run. But If I run the DOS version etrunk.exe, it runs. Is there any way to make it run the Windows version? Thanks.
