Fred1
Is delco fire using new repeaters? The audio sounds low.
I think the whole system needs to be upgraded or changed myself its always sounding low or you dont hear any tones being sent out the only strong signal that comes in is Ridley 7 and 102-A
I kinda feel like that Delco will lean towards a trbo trunked system as the price of the radios will be less strainful on the fire company budgets. A 700-800 mhz system would cost the county a lot of money and companies would not be able to afford the radios that are needed to outfit their people with radios
I have learned from a friend up at fireboard that the new head has been chosen and he comes from a firefighting background in Upper Darby. While you are correct that Delco lacks the funds what you probably don't know is that pretty much every other county has said the same thing but ended up with P25 anyway. With federal funding in the form of grants and such that sort of project would be a little but easier to do. I know in the case of the Bucks County system the fire companies were offered interest free financing or something like that to help make the plunge a little less painful. The fact that DTV interference is an issue within T band I would highly suspect any change would involve a band change. If they go up to 700/800 the feds will likely make them go to Phase II in order to get the funding. But we shall see!
