Motorola Minitor VI 6 Amplifier Charger DIN Alerting Pinout ?
KJ6HCB
San Luis Obispo, CA
Does anyone have a definitive pinout for the Minitor 6 amplified charger DIN connector? Ive seen lots of varying and conflicting info on various forums and posts around the Net, mostly 5+ years old stuff so it may or may not apply to the new 6 model.
Im looking to setup an external relay to trip lights and a buzzer when the Minitor 6 goes off. Ive got the DIN cable, have the LED lights and buzzer, 12 volt power supply, will need to go get a relay but definitely need to have the correct triggers!
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The user guide for the V had the pinout info in it. If you've the charger amp for the VI, do you have the user guide for it?
KJ6HCB
San Luis Obispo, CA
How the hell.... Ive been searching hours for that online over the course of several different attempts, and Im a google master! Haha - thanks!
KJ6HCB
San Luis Obispo, CA
Thanks again! Maybe you or someone else can help with wiring now. I thought I had it, but maybe not.
Ive got a single flashing LED light right now Im testing with, a 110v wall power supply to 12v .75amp, and the Minitor 6 amplified charger.
Power supply plugged into the wall, ground connected to ground of the LED light. Positive from the power supply connected to Pin 2 dry contact, and then Pin 3 dry contact connected to the positive for the LED light. Tones should drop, trip the relay and pass that power through to power the LED Light, correct? I plan to do a relay setup for the full system but im just testing right now to get the correct wiring down.
Thanks!
BigRedBox80
Thanks!
This does seem correct yes. Did you ever give it a try?
KJ6HCB
San Luis Obispo, CA
Yes I tried that - couldnt get the external LED I had hooked up to light or any indication anything was happening. Hoping someone here had a working alert system that could explain how theyve got it setup! Thank you!
KJ6HCB
San Luis Obispo, CA
Bumping this up hoping to get more eyes on it, would like to revisit this project this week. Ive got a Min 6 amp charger and the DIN plug cable but have no idea what to do from here - tried one diagram I found but nothing worked. Help!!
WQUM583
Waukesha, WI
I know this is a year old, but figured it could help someone. I'm still looking for good information on a 5 pin cable with a ground that conducts and is not just a shield.
  • Station Alerting Wiring Schematic.pdf
