Minimal install of GNU Radio without GUI, etc possible?
rosecitytransit
Portland, Oregon
Hello, I am building a Linux server running ClearOS (a CentOS and Red Hat derivative) and, among other things, want to use it to decode and record calls on a P25 trunking system. https://github.com/robotastic/trunk-recorder seems like it does what I want and uses GNU Radio. However, when I go to install GNU Radio, whether the older version that is available through YUM or by using PyBOMBS, it also wants to install a whole lot of other programs, including some GUI stuff. As this will be a server, it will not have a graphical desktop and I don't want unneeded stuff on it.
Is it possible to do a minimal install of GNU Radio with just the stuff needed to decode P25 audio using a RTL SDR and make Trunk Recorder work? Or is what I want not realistic? Thanks.
Kb2Jpd
New York City, NY
You should also State what hardware you are using as a target install. You can use anything from a Raspberry Pi to a blade server.
Later on, you can get an Arch Linux distro and install only what you need. You can also remotely run a graphic head and then slowly remove what you don't need.
Start here: http://files.ettus.com/tutorials/labs/Lab_1-5.pdf
And here. http://raspberrypi.stackexchange.co...rt-a-single-gui-application-from-command-line
Adam Kb2jpd
rosecitytransit
Portland, Oregon
Oops, I did not mention that. It is just a random Dell desktop, an Optiplex 380 to be specific. Thanks for the links, I'll take a look at them.
