Hi All,
I recently programmed my XG-75 Scan model for several local P25 systems. After I initially turn on the radio or change systems, it shows it receiving a call (antenna icon displays) but there's no audio and there's a beep at the end of transmission. This happens a few times with CC Scan displayed and then it works normally with audio. Is there a setting that would need to be changed to stop this behavior? Signal strength on the system per the FCC menu is around -95 DBm on my local system from inside my home.
The firmware in the radio is R02A26 and the RPM version I used to program the radio is R10B07. Radio has options for P25 control channel and Phase 2 TDMA.
And this happens with both Enhanced CC and Fixed Proscan. I'm using Fixed Proscan currently.
Otherwise when it starts scanning the audio is fantastic and clearly puts any scanner to shame in my horrible LSM environment!
Thanks!
Thanks!
