XTS3000 Programing Issues
Rescue_99
Cobleskill,NY
Hi,
So recently I purchased a used XTS3000 from Ebay and received a programing cable and software from the previous user. Now I have it hooked up to my computer and got the CPS R05.03.00 downloaded and the driver that I use for my HT1250 downloaded and when I go to program on the correct COM port it says "Communication with radio failed." Is there anything that I should try or that I am missing? Thank you.
Skypilot007
Medford, NJ
What type of programming cable are you using. If you're using a USB to serial converter check for other available ports. The HT1250 driver you mentioned, I'm guessing that is for a USB to serial converter? When using a direct serial connection no driver is needed.
Rescue_99
Cobleskill,NY
I am using a male 9 Pin to USB Converter that makes it so I can use it on my Computer. And the reason I tried the driver was because it wasn't working with out it and it does not give me an option to use another COM port on my computer.
62Truck
Ordinary Subscriber
Uranus
Need some more info.
The USB Serial converters can be tricky. Some work, some do not. What version of windows is installed onto your computer?
Do you have the correct driver installed for the USB converter? What comport are you selecting?
Rescue_99
Cobleskill,NY
N4GIX
Hot Springs, AR
You can use the Windows tools to (re)assign any COM port...
Outerdog
T¹ ÆS Ø
They are not tricky -- unless by "tricky" you mean don't bother with the README file which explains exactly which USB/Serial adapters Motorola recommends.
