I unboxed my TRX-2 today and set it in place.
Downloaded the TRX-2 Software from Whistler.
Before turning it on, I connected the USB Cable. Got a bright white light saying it was charging.
Turned the scanner on with cable connected, and got a screen that said updated software and firmware were being downloaded. It down loaded the drivers as well; I had no option.
Once all was done, I disconnected the cable. Turned the scanner on, no problems, and loaded my zip code to test it.
It downloaded a bunch of stuff from my area, and started scanning. Got a few distant hits, and I am using the antenna on back of radio.
Then went to software again and checked for updates. It said my CPU and DSP needed updated. Turned radio off, turned it on after connecting the cable.
The Computer and Scanner WILL NOT recognize each other.
Disconnected the cable and tried several times to connect; will not recognize.
Removed cable and got only a bright white screen. Blank.
Waited 5 minutes, nothing.
Disconnected power source, waited a short time, and reconnected power.
Now I have a DARK screen with the words "waiting for main unit." Been like this for 20 minutes.
Now what? Send it back. I am not happy. The scanner did recognize my SD card as it downloaded for my Zip code..but won't talk to the computer.
NOT HAPPY. Help?
NOT HAPPY. Help?
