Is there any software that can view the recorded audio in the 436hp without just transferring the files? It would be nice to keep the screen display like payback on the scanner itself.
MediaMonkey is great for playback, and maintains the descriptions for system, department and channel. You have to move the files though, and I know of no application where you don't, unless you are going to play right from the SD card, out of the scanner.
Thst data is contained in the header of the wav files. You do not lose it by copying to a hard drive or other storage device. You just need an app that address those pieces of info. MediaMonkey does, as do quite a number of others.
WS1095/536/436/996P2/HP1e/HP2e/996XT/325P2/396XT/PRO668/PSR800/PRO652
I figured that but when I tried to make it a video with Adobe audition or premier pro I could not use it only audio so I am looking for suggestions. I will try the 2 mentioned here when I get home.
