I use FMP24 for P25 but also it would be nice to use it for analog fm to considering how lightweight the program is. For the sake of my sanity, is there a way to set the squelch level in this program? Thanks...
Jeremy
Jeremy
Using it in conjunction with DSD+ fastlane version you might be able to use the monitoring modes. Never tried it myself...
DSD+ 1.114 New Features
DSD+: Added raw source audio monitoring modes
The -m<num> command line option and the M/m active keys select one of the five
available monitoring modes:
0: never monitor
disables raw source audio monitoring
1: monitor if no sync and a signal is present (**)
enables monitoring if DSD+ is not detecting known sync patterns
AND noise content is low enough to indicate the presence of a signal
Sooooooo, when should we expect to see this update? That's really cool!
