Andrewc65
Before I dive into the post: All of you Motorola legal freaks - be aware that the radio I am talking about was from my County (photos to prove it was property of SD County are attached). Bought it from the County RCS when they had a radio auction - upgraded to XTS5000's
I programmed this via ASTRO CPS w/ the system key input all my talkgroups and conventional channels. Set the radio to Affiliate "On PTT" w/ scanlists, hidden talkgroups etc.
The system I am talking about is a Motorola Type II SmartZone system. I set the radio to the coverage type of WAC AMSS and input some of the control channels from RR's list of sites. My issue is that when I go to any of the conventional channels that are programmed w/ the trunking scanlist, it is just static. I created Zone 2 and tried a normal 800Mhz conventional channel that I can receive on my MT2000 and it worked perfectly fine.
Current FlashPort Code: 5400080000007
I do know that this radio will work *normally* on the County's RCS since it is directly from the County.
