CM300 internal speaker
KC8OIG
Fort Loramie, Ohio
Hello All we just receive our new pumper truck yesterday and transferred the Motorola CM300 over to it from the old one. The old set up had a external speaker hooked up thru the connector out the rear. We don't have that option on the new truck so we did not put the plug back in the radio. The problem is the internal speaker on the radio does not work. Before we take the radio part to see if the speaker is unhooked is this something controlled by the programming on the pins in the connector?
Thanks for your help
Hiding in a coffee shop.
I think there is an internal jumper that connects the speaker to the audio amp. It may have been removed.
I ~think~ you can jumper the rear pins 15 and 16 to reconnect. Might be worth a try.
Pin 15 = Internal Speaker +
Pin 16 = External Speaker +
I the manual for the radio there is some mention of an internal jumper: Pin 15: Connected to internal speaker (+) and by internal jumper to pin 16.
If the internal jumper was removed to silence the speaker, then this may fix it. Or, like you suspect, someone may have just disconnected the internal speaker.
MTS2000des
5B2_BEE00 Czar
One thing you will notice when you do get your internal speaker jumpered on is that it sucks compared to an external speaker. You'll find out quick is has just enough audio for the typical base setup but not the loud environment of a work truck.
I agree 100%. Inside an engine I'd want the larger speaker. Not only is it louder, I think it makes it much more intelligible.
I've got a CDM running in my F150 and I use an external speaker. Really makes a big difference.
Project25_MASTR
Millennial Graying OBT Guy
Texas
The only way to disable the internal speaker on a CM300 is to remove the front panel and unplug it.
That's what I did with M1225's and SM mobiles but none of my PM400's were ever setup for an external speaker.
KC8OIG
Fort Loramie, Ohio
Thanks for the replies. If I remember right the plug that comes with the radio has a jumper on it for pin 15 and 16. I will see if I can find another plug and try that
