Same Radio ID?
EyesofDeath
Louisiana
My employer issued me a motorola XTS 2500 and then I bought me a XTS 5000. I was figuring that I could keep one at the office and one at home. I programmed the XTS 5000 and everything is working fine. I took both radios home and got to checking the Radio IDs with my scanner. Both radios have the same ID. How is that possible? I thought each radio should have a different Radio ID number?
KevinC
Other
Super Moderator
Home
You answered your own question, each radio "should" have a different radio ID number. But nothing stops you from programming the same in 2, several or all radios.
Makes it a little difficult to inhibit a specific radio and if you're trunking and SmartZone it can cause major issues.
And since you stated you programmed the radio, you are the one that made both radios have the same ID. :D
Is it a trunked system or conventional?
If it's a conventional system, identical radio ID's will work fine, but it will cause issues if one of the radios gets lost/stolen and the system administrator attempts to kill it.
If it's a trunked system, identical radio ID's can be an issue.
Ideally, you do want different radio ID's, but getting those ID numbers really needs to come from your employer. That means you'd need to talk to them, and let them know you have your own radio. This may or may not go over well with the management. Just be ready to justify what you have done. As an employee, you do not technically have authority to add radios to an employers system as the license belongs (likely) to your employer and they are in control of the license and responsible for whatever happens on the system, even your own private radio. Of course many agencies just don't care.
EyesofDeath
Louisiana
So if I was to add another agency to my coworkers radio (yes we are authorized to use the other agency's radio system). How do I keep his radio from changing over to my ID? I mean I dont want to have my 2 radios on my ID and then his on my ID making it 3 with my ID. Does that make sense?
Nevermind, lol, I see what I needed to do. Duh moment
KevinC
Other
Super Moderator
Home
And herein lies the problem with people programming radios on a trunked system...you don't just pick a radio ID, it needs to assigned by the system owner/administrator.
Not when it could jeopardize lives. Programming the same radio ID can have serious consequences for Public Safety Officials and still cost money troubleshooting and diagnosing for both Public Safety and non public safety.
EyesofDeath
Louisiana
I understand the risk. I also made sure that my coworkers radio had the ID that was assigned by they Administrator. I did not change anything on his radio. I just added the Narco channels since we will be working a task force with them.
I asked a question and got my answer. Then I posted a retarded question cause I was dumb and not looking and not reading. After looking at my trunking system info I figured out my own answer.
Thanks for the replies.
