Engine104
Member since 2005
Hi everyone,
I was just wondering if anyone else has run into the issue of a crackling noise along with the audio on conventional UHF frequencies on a Pro 2006. VHF and 800 Mhz frequencies are clear. It almost sounds like a little audio RFI getting into the mixer from a strong FM broadcast signal.
I've ruled out the antenna system by hooking up my handhelds to the discone the 2006 is connected to. The handhelds with their own antennas also don't have the same issue as the 2006. Lastly, I tried using the t 2006 telescoping antenna, but the interference was still there.
Any ideas would be appreciated.
TNX & 73,
-Larry KG6EJT, AKA: Engine 104
TNX & 73,
