I can't post this in the tavern where it would be more suited since the mod prevents me of doing so. So I have no choice as to post here as this would be the most suitable subforum.
I have a garage door alarm that sends a signal to the alarm in the house in the 400 MHz band. I used a SDR to grab the signal and ran the recorded audio in Skysweeper Pro. Upon trying to decode the signal using all the modes available, it looks like this might be MSK or MPSK. I don't know what it is for sure. MSK seems like it could be it since the Hex decode is straight forward compared to MPSK. Also, MSK would seem like a prudent choice for this application since it's not that pron to interference.
Here is the MSK decode:
Here is the MPSK decode:
Audio sample here: https://www.adrive.com/public/k2PDES/sample digital alarm.wav This was recorded in AM. FM did not sound right.
Does MPSK stand for Multiple Phase Shift Keying or Minimum Phase Shift Keying? I'm thinking Minimum Phase Shift Keying which makes me wonder what Multiple Phase Shift Keying is?
What applications use MSK anyway and is this signal MSK?
Thanks!
Note that if this is moved to the tavern I will not be able to respond
Code:
ff a0 00 00 00 00 00 00 00 00 1b ff
Code:
82 88 6c 2c 04 36 06 02 1b 03 01 6d 81 9e 00 00 ..l,.6.....m....
08 00
Thanks!
