Hello all,
I am new to the Vertex Standard line of radios having come from several different series of Motorola two-way radios over the years. I've come across a road bump that is really starting to give me a headache.
I have a VX-800 set up with five groups as such:
Group 1 has 16 channels
Group 2 has 11 channels
Group 3 has 10 channels
Group 4 has 2 channels
Group 5 has 9 channels
Group 1 will scan 13 of the 16 channels; group 2 will scan all 11 channels; group 3 will scan all 10 channels; group 4 will scan both channels and group 5 will scan nothing.
I've set up the scan as follows: in the main window where you set your channel information (frequencies, etc...), I have selected the channels I wanted scanned per each group and selected "DEALER". Under the "COMMON > OPTION" menu, I ensured that the scan list was set to "DEALER". Under the "CHANNEL > CHANNEL ALLOCATION / GROUP TAG" menu, I have ensured that Groups 1-4 have been selected to scan.
I have a toggle switch presently set to enable scan. However, it will only scan the group the radio is presently on and will not check the others. I've tried every possible solution I could think of and cannot get past this issue and I am wondering if I am doing something wrong...? When I have the groups set to SCAN - I notice two dots will appear under the group name when cycling through groups and ".SCAN" will appear when I have flipped the switch to scan. When I have the groups not set to SCAN, there is only 1 dot when cycling through groups (the dot representing the channel in that group is set to scan) and only "SCAN" appears?\
Here's what I am trying to accomplish for example: I enable scan in group 1, I'd like the radios to scan the selected channels in groups 2, 3 and 4 as well. Maybe this isn't possible and I'm misunderstood - or maybe there is some magic trick to get this feature to work? Or perhaps I have a faulty radio. I'd be happy to send someone the plug if they'd be interested in checking my work.
Thanks in advance to anyone who assists!
PS: I am using the windows-based CE-31 programming software.
Nick,
Driv3r912
Nick,
Driv3r912
