I've dug out my laptop and found the freqs and locations for the CNP FD repeaters.
Bellvue:
freq 138.870
lat/long 49.571942,-114.3566667
Coleman:
freq 167.445
lat/long 49.635277,-114.491942
Crowsnest Pass:
freq 138.915
lat/long 49.632500,-114.570277
I used a radius of 30 miles on all three.
If you are in the area, the best time to listen to be certain to get a transmission will be around 1800 to 1930. These departments are part of the fire dispatch system run by Foothills Regional Emergency Services Commission (FRESC) based out of Black Diamond, and they (FRESC) begin pager/radio tests around 1830-1845 each night. FRESC starts with station 1 in Longview and works upwards numerically, so to get to the CNP stations (24/25/26 IIRC), it might take a few minutes.
EDIT: For ease of detecting the talkgroups and etc., I would program them as conventional frequencies with no names (if you program them by hand instead of with Sentinel, you can just not use the "Edit Name" menu; it'll appear to contain a name like "138.9150 MHz" but it'll really be blank). If you do that, the system #, site #, color code, slot #, RID, and TGID will show up on the screen when you receive a signal.
