NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
This might be a long shot, but I'm wondering if anyone is using a PC with Windows 10 to program / control a BC246T? If so, where did you get the drivers needed for the cable?
As I recently said in another thread, I've pulled my 246 out of mothballs to use for mostly conventional frequencies, but may want to program in a couple of trunked systems as well. I spent about 75 minutes yesterday evening manually programming about 60 ham radio frequencies, including alpha tags, in to the scanner. I have a butt-load of other conventional freqs to program in, so I figured I'd download Freescan and use it for easier programming of the scanner.
I thought I had the proper driver(s) installed on my PC, but when I got everything hooked up and tried to upload to the scanner, I got an error message saying that no available COM ports can be detected. When I open up the Device Manager, I see the the little yellow "error" triangle, so I know something isn't right.
So, I'm hoping someone else has encountered this problem and found a solution they would be willing to share. I spent about 90 minutes working on this and am "this close" to throwing either my computer or the scanner across the room into the wall.
Any comments / tips / suggestions will be greatly appreciated. Many thanks in advance.
