FireHousesOfOhio
What's everyone's choice of software to program their BCD436HP? Btw Freescan isn't pulling up.
This is probably not an issue with the software but a setting on the scanner. There are many different ways to avoid, turn off, disable etc. on this scanner and it can be confusing. Make sure any quick keys are enabled, make sure the FL is set to monitor both in Sentinel and on the scanner under Menu> Set Scan Selection> Select Lists To Monitor, and make sure the service types are turned on.Tried the Sentinel & haven't been really impressed. We had ArcButel for the Uniden 396T and will probably be ordering it from Scanner Master this weekend. Is there anyone here that has had success w/Sentinel because we loaded favorites and they aren't playing.
That's been set. The favorites from the software hasn't transferred to the scanner.
Did you check Download = YES on 'Edit Profile' before writing to the scanner?So I set up the groups and completed a write to the scanner and don't see any of the groups listed.
