Apologies in advance if this has been addressed elsewhere; if so I'm not searching for it properly.
I'm running ARC536Pro Version 0.99 Build 5 which indicates as the latest version. With conventional DMR, whenever I start the program and load a file, the squelch mode always shows P25. If uploaded to either a 436 or 536 the scanner obviously does not work properly as a result. Each time I load the file I have to change the squelch mode back to DMR, despite having saved it with that info in the prior session.
Is this just me or is it an issue that needs to be addressed? Other than that I prefer this software for building customized scan lists.
Thanks.
Thanks.
