Thanks for the links.
Although not many specify how many writes a cell should handle before failure, one of the links did talk about the different types of flash memory and I think it was SLC that offered the most writes per cell. They did not give a specific number but it had claims that it could handle 50 times more writes compared to one of the other common types of flash ram.
I'm very familiar with wear leveling. That is of course very important, especially in devices like SSDs. For continuous security video recording where each cell is probably written equally, wear leveling is not as important unless you are stopping the recorder and deleting files often.
It would be neat if there were an diagnostic application that could show the write counts of cells or blocks of cells so you could see if your card was using wear leveling correctly.
I don't know of any utility that breaks down that info though. Some SSD manufacturers do have a utility that can show the total amount of data written to the drive but they don't tell you if a certain block of cells has a higher percentage of writes compared to other blocks.
Speed is not that important to me. As long as the card can handle the data flow without buffering the source, I'm happy.
I do like how they are giving an life rating for continuous video recording.
I can buy cards with a 12,000 hour claim for my security recorders and now have an idea of about when I should swap them with new cards.
I've had quality name brand cards fail before in our security recorders. When I'd need to playback a time period, no video as the card had failed.
I blame some of that on the recorders as well as they should have a method of checking that writes were successful every so often and if not, a warning message should show up on the monitor that the card is failing and an alarm on the recorder for those that don't watch the video being recorded. Our recorders are dated now so that is a feature I'll look for when we start swapping them out with new.
High Endurance microSDXC/SDHC-Memory Cards Durable. Reliable. Credible. high endurance memory card, microSDXC memory card, microSDHC memory card, class 10, extra durable
SanDisk High Endurance Video Monitoring Card with Adapter 32GB (SDSDQQ-032G-G46A) high endurance memory card, microSDXC memory card, microSDHC memory card, class 10, extra durable
it more important to ensure true random write to the card, always starting to write in block 326 will kill block 326 quickly, utilizing all the blocks is the imperative it's called wear leveling
https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=142626
Best microSD card | Best microSD cards 2016 - Test Centre - PC Advisor
