JamesO
So I think now that the Siren App is finally getting sorted out after 2 years, that there needs to be a Master/Sub Siren and WiFi thread for the BCD536HP. Maybe even a specific sub section of the Uniden Forum that then is broken into other parts for things like Wifi Dongle, Android Siren App, IOS Siren App, Networking Problems, Remote/VPN Access, etc..
The reasoning is this.
1. There are Siren specific issues with each App version, Android and IOS that may need to be addressed. Using the term/word "Siren" can lead to a lot of confusion for everyone if the platform is not clearly identified and it makes searching very difficult if there is just a single "Siren" thread. Users will need to weed through everything to find information specific to the App they are working on.
2. There will likely be App specific bugs that Uniden may need to tweak the App for on specific Android hardware vendors. I do not expect this to much of a problem with IOS, but I know for a fact that there are many very small variations in the Android community that tend to be hardware/vendor specific that will need to be discussed and possibly be addressed.
3. There are WiFi specific issues with the scanner/dongle
4. There are Remote Access issues for the scanner than are user solutions like VPN access
5. (I believe) that Uniden has/had plans to allow Remote Access with a "Uniden" solution using some sort of servers and/or software that will allow simple remote access via the Siren App, if this is the case, this should be a sub thread.
6. There are likely networking issues that are not Uniden problems that other forum members can help with and offer solutions for
7. There will likely be bug reports, feature requests and so forth that would be easier to search and track from a specific sub thread rather than mixed into a more generic Tech Support thread.
8. Feature requests or bug fixes for the 546HP Networking, 536HP Wifi Dongle, Android App, IOS Siren App, Remote Access/Connection via VNP, Remote Access via Uniden Provided Network Solution if one ever comes about. User/Forum Member Network/Remote Access Tips, Tricks and Suggestions.
For example, I have 2 specific issues at the moment that should be addressed.
1. IOS Siren App IP Address window too narrow. You cannot see the full IP address unless you actually drill into the IP address setting. Just a simple window width correction.
2. Need the ability to configure a Static IP address for the WiFi dongle on the 536HP. This is a must have feature, do not need to hear about work around with router configurations as many situations/installations you will not have access to the router for configurations.
3. Consider offering a wired network Dongle as an option. This would increase the reliability of the network connection where a wired connection can easily be connected.
4. Seems that the scanner needs to be power cycled after the Wifi has been connected in order for the Siren App to connect. Not sure exactly what is going on here, will need to continue to test to see what is going on.
