Rocky Mount Trunked System
Been going through Rocky Mount for work recently so I added the Rocky Mount Trunked system in my TRX-1. Loaded it directly from the library. It's stopping on the talk group, but I'm not hearing any audio.
Anyone have any idea what I might be doing wrong here?
drayd48
Scanners have trouble on P25 systems with multisites and you are probably experiencing multisite distortion. It is very common with the type of scanner that you are using
LeSueurC
IBEW Local 50
James City Co, VA
Rocky Mount isn't a P25 system. It's a Motorola Type 2.
reconrider8
Eastern, NC
And I don't believe it's multidirectional either. My pro 106 works fine. Is it just 1 tgid that it stops on quiet or what?
No it was several talk groups, didn't hear any. Unfortunately I'm not there enough to spend time testing it. I'm just wondering if it loaded wrong band plan or audio type (though I'd assume it's digital).
Sent from my LGLS775 using Tapatalk
I just loaded it from the library on EZ Scan, I'm not sure.
kc4jgc
Virginia Beach, VA
Reconrider8 is correct; it's Motorola type 2 analog. As long as the control freqs are programmed it should work fine. I was last in Rocky Mount a couple months ago; had no trouble.
Thanks guys headed that way Tuesday and will try again, but it definitely wouldn't work last week
reconrider8
Eastern, NC
make sure you have all the ac's programmed also i think they do roll ccs from time to time and check the band plan and ust check that it is correct
It loads as default trunking tables and type II fleetmaps, is there a custom band plan I should be using? Really appreciate your help.
Okay thanks guys headed up that way Tuesday hope I have it in okay
Thank you for all the input you guys gave me, it certainly helped and today I was able to hear the Rocky Mount system. Noticed there are a number of unidentified TGIDs for this system as my wildcard kept getting hits. Unfortunately, I didn't have the opportunity to log them or identify them as I was driving.
On a related note, also got the Tarboro system to work. Turns out the CC for the system has changed and is now 858.2375, is listed as voice channel in RR database. Also came across two unidentified TGIDs there, 048 is PD Car to Car, 304 sounded like sanitation crews.
Again, thanks everyone!
