XPR7550 Voice Announcement
smorris
WX3PMC/WQWZ815/MOPA-27
Arlington Heights, PA
Does anyone have any experience programming the voice announcement for the XPR7550? I have all my individual channel names recorded in .wav format and the web says the CPS will convert those files into .mva files. When I point my CPS to the folder that contains these .wav files I get an error that says not compatible file type. What am i doing wrong guys?
N1GTL
CT
If it is anything like the XTL/XTS series, the wav files must be a specific size and type.
Less than 58K in size, saved as 8.0 kHz, 16 bit, mono. I have not tried the XPR series and I did not see anything in the help file about that but it may be worth a shot.
smorris
I switched to a different recording program and for some reason, that fixed the problem. I now have custom channel voice announcement! Thank you.
Anderegg
Enter text in this field
San Diego
Which recording program did you end up using? I use the stock VA files for my XPR7350's, but would like custom audio files.
Paul
KA5YTH
Bolivar, MO
I used to fight with voice announcements, then broke down and got the text to voice entitlement. Best $10 bucks I've ever spent on radio stuff.
Sent from my SM-G900V using Tapatalk
Kirk
DB Admin
I couldn't agree more. I've done it for all three of my XPR radios and it's amazing.
ZS6HZ
Sønderborg, Denmark
The Text to Speech license is great. Works like a treat.
However, for my customers who don't want to spend the extra money, I use TRBOnet's text-to-speech facility to record messages.
ch-24
brooklyn ny
worked but new problem
I had the same issue and this answer helped me load the file into the radio but for some reason the file doesn't work on the radio...
I tried loading a recording of the ex-600 alert tones into the XPR7550 so I can use it for my alert tone but the file does not work on the radio (it works on the computer)
N1GTL
CT
Here's a video I made showing how to create voice files for APX....same concept:
https://www.youtube.com/watch?v=Das9WsZMAmQ
I am not sure but aren't Text-to-Speech and voice files for channel announcements different? I though text-to-speech meant the radio would read a received text message out loud. I do not have that installed in my XPR7550. The channel announcement work fine with the enhancement.
ZS6HZ
Sønderborg, Denmark
Text-to-Speech can override the voice announcement facility, so for example, if you select Text-to-Speech for Voice Announcements, and you have a channel that you've named "Security", when you select that channel the radio will say "Security" automatically for you without you having to upload a .wav file.
N1GTL
CT
So it will announce the channel name as entered in CPS without the need to create a voice file?
ZS6HZ
Sønderborg, Denmark
Yes. Within the limitations of it's understanding of the language you've installed.
Although it has a table where you can edit words that Text to Speech can't understand or pronounce.
For example, we use the work "bakkie" here instead of "pickup truck", and if I receive a text about a "bakkie", the Text to Speech pronounces it as "backkey" which is not the correct pronunciation. So I have edited the table to pronounce "bakkie" as "bucky", and now if someone texts me the word "bakkie", my radio will say "bucky", which is the correct pronunciation.
N1GTL
CT
A problem with text-to-speech that I see is your speech is limited to the characters on the screen. If I understand this, you could not announce "new york police, channel 1". It must be limited to the 16 character channel name?
KA5YTH
Bolivar, MO
That is actually the beauty of the pronunciation table. You could set "NYPD" in your table to be pronounced "New York Police." I use text to speech extensively and the major benefit I find is that crews in the field can more easily understand some of my abreviations.
Phillipsc84
Fort Mill, SC
Followup question to this topic, if you have the Text to speech option installed at set up is there not a way to program a button to play the channel name at will? I know it plays it on the channel change and to my understanding there is a "Voice Announcement" button option but it seems to do nothing when pressed.
