There's never any guarantee of being free from mixing products. You can take some steps to reduce overload, like use filtering ahead of your radio, or padding down the antenna line (deliberately reducing the sensitivity of your system) but even that is catchy.
Once upon a time, when I worked in radio in the NYC area more than 20 years ago, the Hoboken fire department was replacing a Micor base with a Spectra. The Spectra was a desktop base station. Their headquarters was looking right into the World Trade Center at the time, and one of the transmitters on the WTC, and one of the TV stations (more than likely Channel 7) was blasting signal right at them. The Spectra, which most people would say was a great radio at the time - and still is - didn't cut it. What ended up happening is that we rebuilt their Micor, making it more reliable (those things are tanks, anyway), and it was able to more sharply cut out the out-of-band signal than the Spectra was - even when it was installed at Stevens Tech, with a direct view of the WTC. So, it's not always the radio. That Spectra was a fine radio. But the environment for it was wrong.
Right now, a lot of 800 MHz systems are once again being desensed by the cellular A and B carriers putting massive amounts of signal into the street, while the radio has to listen to a relatively weaker public safety control channel or voice channel much further away. The solution will be to reduce the receiver front-end aperture so that only the public safety band comes through, and then move as much public safety as possible out of the respective guard bands. This kind of thing is going to happen every time there's something new coming out. LTE is the latest and greatest, and the carriers want to put them up all over the place to maximize their profits ("it's what they do...").
If you have a radio that works, I would rather invest in a "shape factored filter" that has a response that would attenuate anything that's not inside T-Band (that's what's primarily used around Brooklyn). I would also look at my antennas and make sure there is no rust or corrosion anywhere near them that could be a place where signals would mix. I would also pick out a block of VHF that you want to listen to and put some cans on that, or identify what's blocking your signals and notching it. That could help some if the mixing is in the front-end of your receiver (it can happen there, too!). The good thing, I suppose, is that paging isn't popular anymore. There should be fewer 350 Watt base stations on every street corner blasting 152, 157, and 158 MHz signals.
Good luck. NYC is a tough environment. Always was.
