XPR-6550 - Volume Knob Problem
bosco836
I have an XPR-6550 that seems to have developed an issue as of late where the volume on the radio changes when gentle pressure is applied to the volume knob. The radio can be on "full" and with the application of gentle pressure on the outside of the knob, the volume level drops to nearly zero (as indicated on the LCD display). Obviously very annoying, particularly if the radio is on my belt and happens to get bumped.
Has anyone else experienced this? Suggestions?
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Known issue with the 6xxx series radios. Your volume potentiometer needs to be replaced. TT
bosco836
Is this something I can do myself - or something better suited for the radio shop?
Bent_MG
There's some rather significant soldering involved to replace that part - if you haven't done it before it's best left to the pros.
riveter
MD
Yeah the switch pins are easy soldering but the two studs are absolute @$%$&%%#& to desolder and remove without ripping the contact beds off the board.
g6giy
I just did one access is ok.
Lots of heat needed on the 2 studs which are a tight fit before soldering.
cmdrwill
So Cali
Very common problem. I send them to the "Depot'.
If someone out there can do just the volume control replacement, I would send the there instead. I have two more with bad volume control switches.
N1GTL
CT
We do them where I work with a hot air gun. 30 minutes labor plus the part is cheaper than a nearly $300 bill from the depot.
