FlashSWT
Hey guys,
I've got a user who brought me their BCD436HP and after some questioning admitted they dropped it. You actually can't tell from looking at it. Externally it seems to have taken the drop well.
However it is no longer making any noise. It is scanning just fine, the LED is lighting up when it pauses on channels and by all accounts seems to be functioning. It is just not making any sound. No key beeps or scanner audio.
I opened it up and don't see any problems. No cracked solder or other obvious problems. Anybody every seen this before or have any thoughts?
I guess the next step will be to swap in a speaker from another unit and see if it works. If that turns out to be the fix then $10 isn't too bad.
I just wanted to see if y'all had any thoughts before I start cracking open another scanner.
EDIT: The headphone jack still works, so the audio circuitry seems to be functioning just fine.
