GR300 Radio Swap VHF
Tulsa
I have a VHF GR300 with GM300 radios. I need to update the radios for narrowband operation. Looking for the less hassle of swapping radios, something that can replace the GM 300's. Been looking at 750's. Don't need anything but 25 Watt, conventional pl, repeater operation so a 4 channel radio is good.
cmjonesinc
If you wanted to keep the 300's they did make a narrowband version. Check the 7th and 8th digits in the m/n if its a 00 or 09 (I'm about 95% sure on the 09, it's been a while).
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Everything I've seen suggests that the CDM750's are good replacement choice. Assuming the GM300's have and use the 16 pin accessory connector, it's almost a direct swap. The CDM's don't require the loudspeaker jumper that the GM300's do. The CDM's are easy to program for repeater operation.
Tips and tricks at repeater-builder.com for both radios.
SteveC0625
The narrowband version was never type accepted for Part 90 use. And they were few and far between because they could not do 12.5 and 20 and 25 KHz spacing. It was either wide or narrow, but not both.
If the 7th character of the model number is a 0, it's got 12.5 KHz channel spacing. A 2 in that position indicates 20/25/30 KHz channel spacing at VHF
The 9 you mention is part of a 2 character coding for Expanded Logic Board 16 channels. A 0 in the eighth position indicates a Masked Logic Board.
