OK had some extra time tonight and I believe I got it all transferred over. They are transitioning to a VoteScan system in some of the districts. When a user keys up, it picks the best repeater to use for their particular area. You will notice the inputs are all the same even though they should be -45.0 offset for these particular repeaters. I'm assuming this is to activate the main repeater, which then would select the best sub repeater. I'm sure someone can explain it way better than me but that's just the easy to understand explanation.
The new VOTESCAN repeaters are listed as "VS" in the alpha tags and VS# is the different repeaters under that main repeater. Example:
SONORA VS
SONORA VS1
SONORA VS2
Also several talkgroups in the new CALTRANS P25 trunked system were updated as well.
I'll need some help with some of the abbreviations for the districts I'm not familiar with. Unfortunately, the file I received did not have a guide for the locations, so if you recognize the alpha tag, and there is no description listed, that means I couldn't figure it out. Please submit it to the database and I will update it as soon as possible.
Thanks again.
