Delivers1234
Hi all. So do people use capicators to bulk up mobile equipment in a vechicle. I'm planning on getting my ham. I know there may need to be an amp for the receiver.
Delivers1234
Delivers1234
I never thought of the high power car audio types, though I am often reminded they are everywhere when one drives by... I guess I am a dinosaur....
58 Farad's !-- wow!... what THAT must be like to hook up to a battery!.. Arc Furnace!...
...........................CF
Yes (smiling), I can see that creeping up on a full-voltage charge is the only sane way to go....It does give one pause to think about just what super high amperage- low voltages can do...I have a scarred finger- probably for life, when I got a beautiful gold ring between some 15VDC power supply terminals... so much for "low, safe, voltages" (I should have known better and been more careful)
Also, by-the-by, we have a site with one really, Really nasty transmitter-- the details I won't go into.... The power supply is in its own little locked room, with this awesome 'Shorting Stick"-- long plastic handled thing with a 1 inch copper grounding strap, hanging by the door.. what is notable about this stick is it's once pristine 2 inch brass ball at the end now looks like the crater'd face of the Moon-- and anyone one that goes into that room shudders at the sparks and barks from discharging the capacitors....
.......................................CF
forget them. I had a car the kids installed 5 1f capacitors designed to "smooth th power" and keep from 'browning out'. If anything; it introduced noise and caused more brownouts than w/o them. plus they cary a of power that could hurt you.
They are absolutely ****ty for a cb amp....
This is absolutely false if the capacitors are installed correctly. Correct installation is the shortest physically possible run of heavy wire between capacitors and amp, and capacitor leads and battery leads connected directly to the amp in parallel.
If the capacitors are installed in series between the battery and amp, the additional resistance can cause brownout problems.
Capacitors do not generate RF noise, arcing caused by current flowing through a bad connection does.
Capacitors will not solve an inadequate power supply problem, they simply fill in when the load draws large transient currents. The power supply (battery or whatever) has to be able to handle the average current draw over time.
Ah yes, the jewelry- I stopped wearing anything on my wrists- no watches, bracelets... long ago... but my ring I just.... well, I was just stupid.... its gone now too, but that scar remains as a reminder that there are vipers lurking in those innocent (low voltage) cabinets!...
mmckenna;2647602 I've thought of switching to a silicone wedding band said:My wife got used to the idea that I'd be walking around "unbranded" quite some time ago. Better to come home in one piece. However, the ring is the least of things that keeps me in line.
