I've been researching some ways to get better reception in less-than-idea monitoring stations. For example, I typically will set up my scanner when I travel in hotels to search out trunked systems in the area as well as business-band users. 99% of the time, this means that I'm concentrating on 450-470 MHz. I have a high-gain beam antenna mounted on a tripod for home use, however it's much to large and bulky to travel with. I'm looking for something I can fold down or unscrew and put in a small case, then set up on location in a minute or two and have decent reception to my handheld scanner or in some cases an RTL-SDR. I did some testing with a number of handheld antennas yesterday and found that out of all of them, the little telescoping antenna that comes with the RTL-SDR outperformed pretty much all of the others, some of which I paid $20-30 for. I suspect this is because it must create some kind of a ground plane on its small mount, but I was certainly surprised at the results.
I know that Maxrad makes an 800 MHz discone that was designed to be mounted on handheld scanners. I would like to try something similar for business-band UHF. I've found two antennas for sale commercially that I think could do the trick. Obviously I would have to convert from SMA to PL-259 to connect to the antenna. My question is that if I were to remove only the hardware that connects these antennas to a mast, and instead mount them directly to the top of my BCD436HP, for example, how much difference can I realistically expect as opposed to a regular 6" UHF antenna cut specifically for 450-470 MHz?
Here are the two antennas that I'm looking at, one of which is obviously a lot more expensive than the other:
MP Antenna 08-ANT-0891 from The Antenna Farm ($109.95)
UHF 1/4 Wave Ground Plane Base Antenna from Centerfire Antenna ($29.95)
