Baltimore city FD 154.145
kc4jgc
Virginia Beach, VA
Loud buzzing sound like maybe power supply filtering has gone bad. Has this been going on for a while? First time back in the area in 2+ years. I'm waiting to get loaded near Curtis Bay near Ft. Smallwood Rd.
riveter
MD
Someone said it was a phone line issue a while back.
Spleen
Baltimore, MD
That's been going on intermittently for years. I was forced to lock it out of the RR feed I provide. It even defeats the CTCSS squelch on my PRO-106.
ocguard
PA/MD
Do you have it set to NFM? It does mute on our base station but usually with a half-second delay. Before they upgraded our base stations to NFM, it would sometimes override the CTCSS.
Also, I'm told it's co-channel from channel 2 (154.4075mhz) on Cecil County's EDACS, which would explain its intermittency as the CC rotates.
Spleen
Baltimore, MD
I actually thought it was a problem with the PRO-2053 I use for the Broadcastify feed, but it turned out to be a problem with the PRO-106 as well. The PRO-2053 doesn't have CTCSS filtering anyway, so I just blamed it on intermod or selectivity at the time. Pretty sure I'm not picking up Cecil County txmissions, and if someone had a way around it and could host a feed I have no problem passing the torch...
Spleen
Baltimore, MD
If I'm picking up Cecil's EDACS in mid-town Baltimore with a handheld with a rubber ducky antenna, they must be cooking birds in mid-flight at their transmit site.
Changed it to NFM on the PRO-106, no go. Unfortunately, the old 2053 I use to supply the Fire/EMS feed doesn't even have NFM capability anyway.
troymail
Silent Key
I've picked up Cecil's EDACS system on Route 97 in Millersville (south of Baltimore) using a mag mounted RS 800 duck on the roof of my truck.
Spleen
Baltimore, MD
These are using a USB RTL-SDR with a discone, about 40 feet AGL. One is with 0db gain, the other is about 20db gain. I just went to 154.4075, and had to crank the gain past 20db to even recognize that it was a EDACS transmission. The pictured signal is 80ish khz wide, by the way.
ocguard
PA/MD
I misread, thought the trouble frequency was the dispatch channel 154.415, which is closely adjacent to the Cecil freq, and does regularly bleed through our radios when the mic is off-hook (PL disabled).
I'll set our base station to .145 later this week and see if I hear anything.
