BCD-436 DMR & Pro Voice Upgrade Problem
Steve2150
Punta Gorda, Florida
Downloaded latest Sentinel for my BCD-436 and paid for the DMR & Pro Voice upgrades and received my keys, problem is every time I try to enter either key the first letter/number comes back incorrect key entered press any key to continue. Spent time with Uniden customer support, they said I was doing everything right and do not have an answer, they said they are gonna contact Uniden corporate for an answer, any ideas?
KevinC
Other
Super Moderator
Home
Use the scroll wheel to select the digits and the "6>" to advance to the next slot.
KevinC
Other
Super Moderator
Home
So you scroll to the first digit, then press the "6>" and it gives an error?
UPMan
In Memoriam
Arlington, TX
The scanner only checks for validity after you press E. You should only do that after you've input the entire key.
Steve2150
Got it was not using the 4 & 6 keys to move digits, thanks everyone for help. Question I use it by entering zip code & range, not very good by individual manually entering, does the dmr & pro voice work automatically or do I have to enter the settings, thanks again.
