Unication G5 AES encryption support
JASII
Memory Capacity
Unication G5 AES Encryption Support
You have to send Unication David a message and he can email it to you.
SOUTH300
Carencro, LA
Outcome
I've seen numerous references to AES encryption support in the G5 - where is the configuration found for enabling and entering a key?
Lindsey, were you able to get information on this? I am curious if they also support ADP.
JRush311
Monroe, N.C.
will this make it able to hear encrypted calls?
or just block you from hearing the insane noise it makes
troymail
Silent Key
You cannot listen to/hear encrypted communications unless you are authorized and have the key.
The Unication pagers will pass the encrypted "gibberish" to your speaker and will not mute it.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
far as i know these pagers don't cover encryption YET
If you read the thread from the beginning, you will see that they do cover AES-256 encryption.
You'll need to contact Unication David and once you have the required information and the actual key, you will be able to listen.
