NJDEP/NJFFS Conventional Frequencies
Joseph11
Over the years, I've collected multiple different frequencies for the NJDEP/NJFFS and at this point am not too sure which are still accurate or current (or incorrect). What I have is a bit different than the RRDB. Does anyone involved with the NJDEP/NJFFS have any input on the following?
Code:
CHANNEL 1       	 151.190000	 NFM	 CTCSS	 179.9	    0
CHANNEL 2       	 159.300000	 NFM	 CTCSS	 179.9	    0
CHANNEL 3       	 151.325000	 NFM	 CTCSS	 179.9	    0
CHANNEL 4       	 159.345000	 NFM	 CTCSS	 179.9	    0
CHANNEL 5       	 159.465000	 NFM	 CTCSS	 179.9	    0
CHANNEL 6       	 159.375000	 NFM	 CTCSS	 179.9	    0
CHANNEL 7       	 151.415000	 NFM	 CTCSS	 179.9	    0
CHANNEL 7A      	 159.240000	 NFM	 CTCSS	  82.5	    0
CHANNEL 7B      	 151.265000	 NFM	 CTCSS	  82.5	    0
CHANNEL 7N      	 151.265000	 NFM	 CTCSS	 131.8	    0
CHANNEL 8       	 151.475000	 NFM	 CTCSS	 179.9	    0
CHANNEL 8A      	 159.270000	 NFM	 CTCSS	  82.5	    0
CHANNEL 8B      	 151.475000	 NFM	 CTCSS	  82.5	    0
CHANNEL 8N      	 151.475000	 NFM	 CTCSS	 107.2	    0
CHANNEL 9       	 151.265000	 NFM	 CTCSS	 179.9	    0
CHANNEL 9A      	 159.405000	 NFM	 CTCSS	  82.5	    0
CHANNEL 9A      	 159.405000	 NFM	 CTCSS	 179.9	    0
CHANNEL 9A      	 159.405000	 NFM	 CTCSS	 123.0	    0
CHANNEL 9B      	 151.415000	 NFM	 CTCSS	  82.5	    0
CHANNEL 9N      	 151.415000	 NFM	 CTCSS	 131.8	    0
CHANNEL 10      	 159.285000	 NFM	  None	      	    0
CHANNEL 11      	 159.435000	 NFM	 CTCSS	 179.9	    0
LOCAL           	 159.615000	 NFM	 CTCSS	 179.9	    0
Thanks!
jeff
St. Augustine, FL
Here's the 'official' Forest Fire freqs. The 151.19 and 151.325 DEP repeaters have the same frequency pairs but different PLs at their sites. I'm trying to find my lisiting for that.
Analogrules
I believe the majority of DEP ops are on NJICS and the State 800 Trunked system now. I haven't heard anything on their conventional frequencies in a long time (but haven't really spent too much time listening either). Perhaps a couple of them are still used as back up/inquiry channels?? Perhaps a few of us can program these conventional frequencies into our scanners just for fun and report back if we hear anything and from where.
Joseph11
Thank you so much, jeff! I had a feeling my list wasn't entirely correct.
N2ZGE, aside from the NJFFS frequencies, I don't hear much or anything at all on these.
GM
Yes, all of the frequencies listed above are still in service, except the "Local" channel and the 7B/8B/9B channels. Local was used by Section B-10 for a short time before moving back to the state assigned freqs. They also used a privately licensed VHF business repeater for some time after that but that has also ceased to be in use. Most of these VHF freqs (except FF and Parks which are still full time on VHF) are now used as a back up to the State 700/800 systems where coverage is still spotty. I was using a few of the frequencies at work this past weekend, however you won't hear much this time of year.
Joseph11
Are the "B" frequencies and "local" still programmed in radios or are they completely discontinued?
Tech792
Central NJ
The "B" channels were only proposed at one time and never used. They were never programmed. And the B10 local channel is no longer in the B10 radios. The above chart that Jeff posted is the current channel plan.
Joseph11
Thank you, guys, for all the information! I've submitted this all to the RRDB. Last question (or at least it should be):
Code:
159.40500 	KYD792 	M	123.0 PL	Island Beach	Island Beach State Park - Lifeguards 	FMN 	Public Works
Is this still in use or would this be considered deprecated? When I lived closer to IBSP, I don't recall ever hearing anything on it. I would hear IBSP units on channel 5, I believe.
GM
Still very much in use. Most of the freqs are low powered 5 watt radios or the 45 watt car (mobile) radios and in simplex mode, so you have to be close to hear them.
question about these frequencies
What frequency would you hear say a major event or what frequencies do they use most?I never hear much of anything.I did have my radio on code search and a DCS code came up on one frequency with 606,so are the PL's correct or am I hearing something else.Keep in mind I have a portable.
Analogrules
I would assume that they'd use the tg's on the State 800 system and NJICS for anything major.
Joseph11
With regards to the NJFFS, channel 6 and your division's repeater are the most used. Channel 6 is most commonly used for local fireground. The PL tones listed are all correct.
GM
Before some mis-information goes around, let's clarify the different uses of the various Divisions:
Environmental Response - NJ ICS 700 as primary, VHF Ch. 1 & 2 as back-up
State Park Service - VHF Ch. 5 (Island Beach State Park Lifeguards - Ch. 9A)
State Park Police - NJ State Police 800 TRS as primary, VHF Ch. 1, 2, 5 as back-up/inter-ops.
State Forestry Service & Forest Fire Service - VHF Ch. 6, 7, 7A, 8, 8A, 9, 9A, 10, 11. Future plans to use Ch. 1, 2, 3, 4 are currently being talked about, but not finalized.
Fish & Wildlife Division - NJ State Police 800 TRS as primary, VHF Ch. 3 & 4 as back-up.
There are future plans for State Park Police and Fish & Wildlife to switch over to NJ ICS 700, but has not occurred yet due to funding issues purchasing the new radios. The new radios were purchased for the Environmental Response Bureau first since they were having issues communicating on the VHF analog repeaters throughout the State, I was told.
And as Joseph11 stated, the PL tones listed in the database are all correct.
