Oh look, another 668 issue
firecatohio
Logan, oh
Went to hook my 668 to a new computer, and low n behold, can't load software! Got a error message..
Sent from my SM-N920V using Tapatalk
JD21960
ILL-annoyed
Check RRef search box for the answer. It's been given out with each new scanner from the GRE-PSR800 to the WS1080, RS-Pro668, WS1088, WS1095-98 and the new TRX-1/2. This same problem was discussed with each one of those in the forums.
jim202
New Orleans region
It would help to provide an answer if you provide some more info when you ask a question like this. Not trying to be a pain, but look at it from the other side here of the people that might have the solution for you. Give them something to work with.
What version of Windows are you using?
What exactly is the error message your getting?
Did you set the connection type in the software you were using? I say this because some software use the serial connection and some use the USB connection.
What software are you trying to use to communicate with the scanner. There are several software packages that are available to communicate with the scanner.
firecatohio
Logan, oh
Reoccurring problem
Again trying to work with this pro668. I get this error message when trying to setup on computer. What do I need to do since my scanner is now a useless unprogrammed paper weight...
firecatohio
Logan, oh
Blackswan73
Central Indiana
Looks like your install file is corrupted. You can get another install file, or you can just enter your zip code. The scanner can be programmed without using a computer. In, I never used the software on any of my 668's
firecatohio
Logan, oh
Hard to update without software.. plus when input my zip, it says nothing to play
Blackswan73
Central Indiana
After you enter your zip, it loads channels from the database on the SD card. After it is done, it will ask if you want to save. After it saves the channels, make sure your channel lists are enabled. By default they will be 150-200. Unless your area has had recent frequency changes, or talkgroups added, there is no need to update the scanner. As for the software, there are several threads on this forum that has links to download the software. More info on programming your scanner can be found here:
Easier to Read Pro-668/PSR800 Digital Scanner and EZ-Scan/iScan Software Manual
Thats a website at .net ,surely you must have a virus of some sort.Run AVG free full scan and let it finish. or try and get the download from another computer,that one you are using is compromised. Test it,try and get it from the Radio Shack site or from someone on here get the software. check this thread also : Radio Shack Scanners - The RadioReference.com Forums
